Corrugated plastic roofing
Discussion in 'Builders' Talk' started by mike2014, Feb 9, 2014.
  1. mike2014
    mike2014 New Member
    During the high winds a part of my garages corrugated plastic roofing came off. Needless to say it shattered. I want to replace it but unsure of how to cut to size without shattering or breaking - does anyone know of a foolproof way for a novice to do this?
    Ted Leger likes this.
  2. Phil the Paver
    If you are replacing with new sheets, it should cut ok with a fine toothed saw, put masking tape on it where you plan on cutting it, easier to mark a line on and supports the plastic a little while cutting.
    The older sheets will have gone brittle with age, hence why they shattered.
  3. mike2014
    mike2014 New Member
    Thanks Phil much appreciated I will take your advice and give it a go
  4. Ted Leger
    Ted Leger New Member
    Sorry, I probably am a little late in responding, but just in case I went ahead. Actually, working with these sheets is easy and aren't difficult to cut. When they are new, they will last a good bit longer than one would think, so you do well just replacing what was broken. You just have to make sure that the laps are the same, or it won't fit together correctly and the roof will leak in that spot. I found a site that talks all about these sheets, it is at https://plasticroofingsheets.net There were a few things on the site that I didn't agree with, but for the most part it does have good information such as cutting the sheets, different types, etc..
  5. mike2014
    mike2014 New Member
    Thanks Ted I will have a look at the site you suggest for future reference. I am all sorted now I did has Phil suggested and worked a treat - thanks again
  6. Jaric Willows
    Jaric Willows New Member
    I think you should take that shattered area apart and cover it with another one. I have very less experience in roof construction and maintenance, but I would suggest you to bring a new sheet from market approximately a few inches bigger than original size. Put that new sheet on the shattered part and seal it with a good paste.
  7. Cyrax
    Cyrax New Member
    I used to work in a plastics factory with polyproylene sheets. If its the same stuff, it cuts really easy with a stanley and you can melt sheets together with a heat gun with a flat end.
  8. Mr. Handyandy
    Mr. Handyandy Screwfix Select
    Did you get the sack?
  9. Cyrax
    Cyrax New Member
    Erm, no.?
  10. Jaric Willows
    I always feel terrified while using heat gun.
