It's not something I'd class as vitally important in the grand scheme of things it's only really an identifier to point out what everyone already knows.
Coloumb you are correct my friend, no need for the doubt in your closing sentence and nobody is disagreeing with you. Sleeving is not insulation it is an identifier.
But it is instructed that sleeving should completely cover exposed wires and that no bare wire is visible! Therefore, it acts as insulation. (In the case of bare earth wire) Mr. HandyAndy - Really
Simply not the case old fruit. If it were then there would be no such things as exposed or extraneous parts.
'Course there would. Screws, metal parts, pipes, brackets etc I would not consider a bare wire inside an enclosure as extraneous or exposed. I would consider it as uninsulated. Mr. HandyAndy - Really
No it isn't instructed at all. Sleeving is just an identifier and doesn't have the same properties as insulation. It is too thin and doesn't grip the conductor at all. Can I ask? Why do you insist on trying to make a case for justifying bad practice?
