I have some perspex sheet - about 2 or 3mm thick - and I want to cut it. I've tried various methods (hacksaw, jigsaw, scoring with a carpet knife etc) but it's a right b**r. Any ideas on how it should be cut?
With a fine point saw(32tpi)much like a tenon saw, and cut along(narrow angle) rather than down through(steep angle). Clamp/hold it well while cutting - keep straight and don't let it flap. Mr. HandyAndy - really
For thin acrylic, ie. less than 4mm thick scribe breaking is probably the easiest. There are a few methods ** Message was edited by: Screwfix Moderator
Hi....ooh i thought us women could *****!! ...all i wanted to know was ;-..how do i cut a large piece of mirrored perspex please...now no ******** fella's ...just a simple answer will do asap..in anticipation many thanks Sandy
Beeaatching?! You've been given three different methods from 3 different gentlemen. (cough) For 2 to 3mm acrylic, I'd be tempted to go the score 'n' snap route. Use a metal rule and score gently using a Stanley knife exactly where you want the cut. Go over it a few more times - don't press hard or you're more likely to go wrong... Place the score - facing up - fractionally beyond the edge of a good straight firm board or table. Place another board on top - again with the score chust beyond t'edge - if you need to keep it all from slipping around, and bend the b'st'rd. Unless it's a large sheet...
He's at it again though, that Uhandyman. First showing a scribing blade in pictures to score the sheet(and making the effort to highlight the type of blade), then a video showing a normal straight stanley blade. Make your mind up. Mr. HandyAndy - Really
I've always used a jigsaw to cut the perspex, then once it's done you can give the edge a great finish by giving it a gentle heat with a gas blow lamp. Sounds strange, but it gives it a brilliant smooth finish, just don't melt it!
