Decking Stain off Flags
Discussion in 'Landscaping and Outdoors' started by Barney Rumble, Jun 4, 2014.
  1. Barney Rumble
    Barney Rumble New Member
    Hello All,
    I had a good set of new flags laid a few years ago, and god knows why, I decided to put decking on them...anyway, after that big mistake, I have ripped decking up and hence my flags have all the previous years decking stain soaked in....I am resigned that this will not come off, any ideas? cheers in advance
  2. Mr. Handyandy
    Mr. Handyandy Screwfix Select
    Best to try a pressure washer. Chuck soapy water over it the night before.
    Mr. HandyAndy - Really
  3. Phil the Paver
    You try washing the slab with a mild mix of brick acid, say 50/50 with water, before giving them a jetwash.
  4. Need a bigger hammer
    Need a bigger hammer Active Member
    Put decking stain on the rest of them. Then tell everybody that it's a new idea that is starting to catch on...:p
