Hi, I'm laying 10mtrs of 3 core 2.5mm armoured cable from my house, across the lawn and to the garage, and wondered if there was a minimum depth which armoured cables need to be buried? I hadn't planned on any other cable protection other than it's own 'armour'.
Not for domestic installations. It just has to be buried at a sufficient depth so that it is unlikely to be damaged.
Narrow trenching shovel/500mm deep/10mm pea shingle on bottom to what 75mm/lay SWA on bed/ 150mm 10mm pea shingle on top of SWA/electrical hazard tape/backfill and use cut turfs if applicable/job done to regs/thankyou
Sifted Sand, filtered soil, rock sand,cable, filterd shell sand , clay tiles , warning tape, then soil to finished level. If you are going to do it ,then do it right JP Pea stones !
Excellent, JP, but there is no real point putting all the extras in the split. It is just as easy to make a split along hte lawn using a spade. Push the spade in, rock it back and forth to open up a slot in the lawn, and repeat next to it. This will create a narrow slit along the lawn about 200mm deep. Then drop the cable in and press it down in to the botoom of the splt. Then 'fold' the lawn back together over the cable and tamp down. Might need a bit of soil filling in places but thast about it.
Good idea Un, simple method the brain doesn't think of but in a lawn would you consider 200mm deep enough , what if
Perfect Lokks Trenched to 500mm, bito sand, cable on top and still leaving the exact 457.2 mm of depth above the top of the 10mm SWA to the finished ground level. Cunnnt be better!
The 450mm depth is, I believe, an historical one. It would be below the cutting edge of a plough in farmers fields. Unless there is adire need to plant spuds, plough the lawn and scatter good seed on the land, I really don't see why an armored should be buried in a lawn any deeper. I call a spade a spade.
That trench aint for SWA LD - I bet some 110/160mm orange is going down there - possible land drain but unlikely. That's a length of cut off SWA (in fact it might not be SWA at all) and the geezer is aving a joke..
Shoulda gone to Specsavers JP as I can see the SWA by the guy in the trench stretching back along the trench to the shed. Pukka job, barriers and all!
Totally agree Sine that geezer knows where he is at - lovely well presented job - but I have exploded the pic to degraded pixel level and still cant see the SWA in the actual trench -
