I have a hole to drill in a cavity wall. Brick outside, concrete block inside (not thermalite). I've drilled 120mm using a hand held cutter hired from hire shop before, and it was OK if a bit of a handful. I would like to take this one out to 150mm, but wondering if this is a bit big for a handheld cutter. Do you guys regularly drill 150 hand held? or should I stay safe and go for 120?
Seen someone break their wrist doing this, it took a millisecond and snap, oh the pain in their face, still see it now.
Seen someone have his nose broken,blood everywhere, idiot was using core drill at shoulder height, when it jammed,had he been on steps it wouldn't have happened.
