I've installed a Netatmo thermostat to control my central heating. This means I don't need the control on my EP2002 controller. I've put the Central heating control on 'always on'. Does anyone know how to disable the EP2002 Central Heating control rather than just leaving it always on (as it wastes energy lighting the lamp, albeit a minor amount). Also it can be inadvertently switched off there.
Hi At the wiring center, take out the switched live heating call from the timer, and replace with a permanent live! Regards Peter
Yes but nowadays with all the certification that has to be done we use our own sparky for the electrical side
the system you have simply need a permanent live, this fires the heating, via your remote/moden linked, room stat regards peter
No idea! But I think it's sorted now. Someone told me the wires to relocate and which terminals. Thanks for your interest.
Yes, I already had the thermostat working to the app. Someone has told me the terminals and wires involved to disable the EP2002 switch. Thanks for your interest.
