lets keep it simple assume internal flush doors (so no "middle of the centre rail" answers) assume new housing (so no "copy whats already there" answers) now two questions requiring two answers what height do you install the handles at what authority do you claim as basis of your answer i cant find a british standard and googling it comes up with the following answers the cfg.gov.uk site (school furniture site) says for 18 year olds 900 to 1000 a UN website say 900 to 1000 the manchester university website says 1000 to comply with the disability discrimination act
what height do you install the handles at 900mm what authority do you claim as basis of your answer Thats what i have been taught.
vinnie this all came about because i installed at 900 as i was taught and was told it was wrong my problem is that i cant give an authority AND the guy who says different cant quote an authority either
950 is what this guy says oh and just to help the old carpeneters used to say 39 inches which is as near as damm it 990
Are we talking new build so Part M would apply? If so - 900mm - 1100mm. So you're not wrong - but neither is he.
It is a well known fact that the internal door handle is set at the exact height of an average height man's hip. The average man being 5'10", the top of his hip being 3'(or 900mm) approximately. There are people walking round with permanent scars on their hips at 900mm from walking into georgian/victorian door-handles all their life. So it must be true. Mr. Handyandy - really
My City and Guilds course outlined that the positioning of the centre of door spindles should be at 900mm to 1m from floor level on internal doors. Always been happy between them heights.
Politely point out that that is the height you were taught to fit handles at, and in the abscence of a written specification directing otherwise...
Hi DD, In the absence of a middle rail, I was taught 990mm from bottom of door to centreline of lever. City & Guilds, Institute of Carpenters.
thanks to everybody its confirmed what i thought i did it the way i was taught, the other guy was taught slightly different. there is no one single answer
If it is a Metric door I ensure that the latch is 1020 mm up and the spindle positioned at whatever height is needed to make that work. Reason for this is that the main supplier of these doors (Swedoor) makes them symetrical top to bottom so that the prehung doors can be turned up side down and used in left or right hand frames. With Swedoor latches this means the spindle is at 1040mm but with a core conventional lever latch the spindle is at 1020mm. On an Imperial door I go for the spindle at half way (990mm) unless there is a structural reason to avoid this. The mid rail is usually lower than this so no restriction there. Reason .... it looks right.
i have allways placed the handle hight at 990mm to the centreline of the latch wether there is a middle rail or not.
