Dual flush syphon not working correctly
Discussion in 'Plumbers' Talk' started by Steve698, Mar 22, 2017.
  1. Steve698
    Steve698 Member
    Just replaced all the internals of our old toilet. Installed new dual flush syphon and new fill valve - both the same make. Everything is working fine except the half flush (pull handle and hold) isn't working, it just full flushes whether you pull and release or pull and hold. Anyone know what might cause that to happen.
  2. KIAB
    KIAB Super Member
    There usually a plug in side of syphon that sets fill level 6ltrs or 9 ltrs or what ever, have you check that.
    What make of syphon?
    tore81 likes this.
  3. Steve698
    Steve698 Member
    It's a viva skylo -- here. There is nothing in the literature to explain.
  4. KIAB
    KIAB Super Member
  5. Steve698
    Steve698 Member
    i have both plugs in just as it came out the packet.
  6. KIAB
    KIAB Super Member
    Remove one.:eek:
    Both in gives 9ltrs, also 6trs & 7ltrs options depending on plugs locations, all in instructions.
  7. chippie244
    chippie244 Super Member
    I've told you before, there is no point spamming a British forum. :mad:
    KIAB and Dr Bodgit like this.
  8. Dr Bodgit
    Dr Bodgit Super Member
    Everyone knows that KIAB is many times more useful than those idiots on youtube.
    Go away you idiot troll.
  9. KIAB
    KIAB Super Member
    :eek::oops:[​IMG]
  10. Steve698
    Steve698 Member
    Ok thanks everyone for your replies, its sorted. Turned out to be the c-link not pulling the plunger all the way up - shortened slightly and all is well.
  11. KIAB
    KIAB Super Member
    I was just about thinking about that, nothing else it could be.:)
