"Eclipse Single Chain Spring Door Closer"
Discussion in 'Carpenters' Talk' started by liam casey, Aug 7, 2014.
  1. liam casey
    liam casey New Member
    I see that others have managed to install the "Eclipse Single Chain Spring Door Closer" (e.g. 59375), but I cannot work out how to overcome the strong spring using the "template". The instructions get very vague at that point. Can someone give me the details, or is there a video (I can't find one)?
  2. CraigMcK
    CraigMcK Screwfix Select
    About 2:30 into the video
  3. liam casey
    that was fantastic, thank you for your video reply , will be able to sort it now ,thanks liam
