hi,i'm a worrier so here goes,electric shower in 1980 house new fuse box correct rcd right rating for shower outside bathroom neon light on off switch but found commons where a wee bit loose only got 1cm slack on cables in back box see correct 10 mm cables but as 10 mm cable goes thru wall to triton shower is in sheaving bit too long unit on cable side sits 1 cm proud pushing unit away from shower wall all works fine rcd has safety trip button beneath off/on switch.is this set up safe as its slightly off tiles behind unit all screwed to wall and tight. regards to you all,cheers
Can you take shower off the wall,cut back sheathing so shower sits tight against wall? Or, is there any way of removing some plastic on back off shower to allow sheathing to poke through? If not, then just silicone around the shower/tiles.
