What would you chaps use to extend the wires of a double socket? I am thinking ahead and thinking that if the there is not much slack for when i go out approx 65mm from old wall i may not have enough to extend the sockets onto the new Plasterboard! These any good: http://www.screwfix.com/p/ideal-spl...tracking url&gclid=CKeArbrty9ACFaEL0wodRMkFKA
Why would i need these? I will be using plasterboard socket back boxes and have the cable come into them from the rear
http://www.screwfix.com/p/appleby-2g-35mm-dry-lining-box/36960 Something like this is what i will use
In my experience.. And only my experience you should only use that style for switches as when you're pushing to put plugs in you can damage the plasterboard . personally if there was a sturdier option I would take it.
I am insulating it. Battening, insulation, vapour barrier, 12.5mm plasterboard. Very cold external wall.
Oh right. When you have done the battening is it possible to put in a couple of noggins so as say a 35mm galv back box can be used? Say screw the bottom 2 x 2 noggin horizontally first (the top of which will be the height of the socket from the ground) and screw the back box onto this leaving it so the box is flush with the noggin, and then put the other noggin on top and finally secure? And then you can plasterboard as per usual.
Last resort Kool really..its only a bit of extra work to fit galv But hey Kool its your job m8--whatever you thinks best.
Dry lining boxes should be fine. Just cut neatly- nice and tight. It is when they are used with 9mm board that you should worry.
