We have a utility room in which we have a single double socket on the wall above our worktop. I'd like to install a washing machine and tumble dryer in there, but obviously don't want them both running through the same socket. Can we arrange for a 30a junction box to be installed, and take two feeds off, each to a 13a fused switch (above the worktop), with 2.5mm running down to a single socket underneath the work top, one for each appliance? I'll have an electrician carry out the work (he's on holiday atm, just want to buy everything needed ready for when he gets back). Cheers, Jay
Could easily split the ring final & have two switched fused connection units in a dual back box,need a short link between to continue ring final, I prefer that to having seperate spurs, each fcu then has a 2.5m T&E drop down to a unswitched 13A socket, making sure it isn't in the way when you push the machines back. Got caught here,I forgot about the raised back on the Bosch, so had to move socket & offset it a bit to one side.
That's great thanks for your replies. So i need 2 13A FCU's, the backbox, some 2.5mm, and two sockets? Is this okay in the small square conduit that sticks on the wall?
Yea but your spark will probably have a preference for the make of the accessories so better check with him first *cough*. Don't bother with the stick on stuff, it's useless, get normal trunking and screw it to the wall.
Says who, on every 30A JB I have ever fitted it say 4 x 2.5 max. If its rated to 30A then whats the problem if its on a 30/32A protective device.
My understanding is a u/f spur should only feed 1 double socket max so technically you could end up with 1 spur feeding 2 x double socket. Daft though as you could use two jb's and run a 2 inch piece of 2.5mm between them.
Are we sure the existing double socket is on the ring and is not an unfused spur which can not be further extended?
I'm not pretending anything. My mates on his honeymoon who will be doing the work when he returns. The socket is straight on the ring.
I was on a job not two weeks ago where that exact setup was installed but, they were all part of the same ring, just looped from socket to fcu to socket to fcu and so on
Hi Never - the two fcu's are spurred from the Ring Final Double Socket via one length of 2.5mm from ds to fcu's ..
