We are having some brick slip/tiles fitted to an internal wall, which has been plastered. What is the best adhesive to use? Thanks Colin
Wall tile adhesive. Hope the plaster if fully dry, usually allow around a month, otherwise they will come off, as they will if the plaster has been polished too much. Would then need to prime first with SBR diluted.
Darn phone & most peeps point in with a proper mortar mix with a mortar gun, then go over with joint tool.
Having a quick look at the various brick slips available, most go for a rapid set flexible wall tile adhesive. Check with your supplier & see what they recommend. Also mix your slips from 3, 4 or more boxes, as there can be sometimes very slight colour varitions when firing.
