Could anyone please post the fitting instructions for a Flomasta 25-6-130 central heating pump please.Thanks in advance
What's the issue wrighty. Undo the nuts on the old one, slide it out, slide the new one in, tighten up, job done. Oh, better get the water off first though. Need lots of towels. May not be able to get those big nuts undone without a 54mm spanner. Make sure you get the flow direction arrow the right way round... Nothing to it. Call in a pro Seriously, if you can shift the 54mm nuts the job should be a breeze. If not, drain down, fit new pump valves with the new pump Good luck
Thanks for that I have fitted them before, its just the instructions for this particular pump that I need, because on the Screwfix reviews someone has mentioned that the pump spindle needs to be horizontal
