Hi Folks, I am looking to install loft boards however One single board will not reach between 4 beams fully often falling short of the 4th beam by afew inches. Is there anything I can get that I can place on the beam like a support. I seen in this picture: http://www.post-carbon-living.com/PCH_Pictures/Insulation131172.jpg Where there is a bit of metal on one of the beams. This is exactly what I would be looking for. Does anyone know what they are called?
Is this a wind-up or not? If the boards are too short , then just screw another piece of timber alongside the exisiting joists. Maybe my builder friends will shoot me down on this, but I really can't see a problem.
you're on route there to fueling the economy, Once you've made that attic a storage space, you'll begin to fill it with all the crup in your bedrooms,drawers,under the stairs and corners of your house, you will feel great at first cos you've solved a clutter problem, but slowly but surely you will start to fill up the empty spaces faster than a tramp on a kipper, then you'll need a bigger attic,So you build an extension and the process starts all over, STOP NOW, think, stop buying shoite from £1 shops,
My Fiance and I have bought a house and she is moving in so allot of the stuff that is from her Parents House is coming to ours so we need a bit of extra space. See I would screw a wood batton but I would also like to beable to walk along the attic? And If screwing a wood batton to a beam is the idea then would this not create stress?
If they are too thin for both edges of your loft board to sit on then they are too thin to take the weight of the loft boards and whatever junk you want to put up there and your ceiling is going to collapse.
What I mean is say If I have a loft board it will cover 3 joists perfectly well. It will however fall 1 inch short of reaching the 4th Joist. What I am wondering is there any plates or whatever that can bridge this gap that will alow the structure to remain solid.
The first board might only be an 1" short of the 4th joist, but that then means the second board will be 2" maybe 3" short depending how you started, the 3rd board will then be even shorter and so on, so as already been said, cut the boards down to suit the joists, not mess about trying to suit the boards.
OPTIONS, Either cut the boards. Glue and screw timber to side of joist. Fix two pieces of timber at right angles to the joists. Use tongue and grooved flooring. Get a Joiner in. Is this a Cut or Trussed roof?
Has anyone thought of putting manufactures instructions in the loft board packs? it seems there's a need,
Think laminated flooring and apply that logic to loft boards! As chippie said, cut board to suit width of ur 3 joist.
