My shower cubical is fully tiled and wanting to fix a set of shelves (just the little ones used to hold shampoo bottles etc) in the cubicle. What fixing should I use for these, the tiles are on a plasterboard wall, also should I seal around the holes once I drill and fix? Thanks
You can get shelves which use a twist lock vacuum fixing and ones that glue on if you don't want to drill.
Trouble is plugs into PB wall will soon work loose I recon. Couple of large bottles of shampoo / conditioner can be heavy Would be better to screw into studs, noggins but knowing where they are under the tiles may be a problem Stainless steel screws are a must - possibly supplied with shelves but a lot of supplied fixings now are rubbish I've always pumped some silicone into rawlplug before adding screw. Maybe not essential but I like the idea anyway
