Just putting the finishing touches to my kitchen but have one question. I have an open end base unit which mean i will have to mitre the plinth for the 45Degree angle. Not a problem in itself but the end units have no legs they are fixed to the adjacent unit so I cannot use the normal method of pushing onto the legs. What would the pros do!
heelllooo wardross assuming ive read it properly secure to bits together at the back with blocks 2 by 2 or whatever secure a batton on the wall also on the end of the unit to give you somthing to fix to if you may need to get access use silicon to secure if not no nails should do it would also to fix a support on the corner for it to fix to [but 3 inches clear of the corner enough for any blocks on the plinth to clear hope this helps big all
