Fixing timber to steel beam
Discussion in 'Carpenters' Talk' started by redrobh, Mar 7, 2007.
  1. redrobh
    redrobh New Member
    Hi other than shot firing what is the best way to fix a 100x47 timber to the top of a steel beam?, can self tapping screws be used?
  2. jasonb
    jasonb New Member
    Drill the steel clearance for M6-M8 bolts and bolt the timber to the steel.
  3. jasonb
    jasonb New Member
    Or drill say 5mm and screw up into the timber with 4.5x40 screws, probably the easier of the two.
  4. dunc
    dunc New Member
    I had to do this two years ago. Drill the holes as and where you need them. Then tap a thread into the holes. Then use bolts, not self tapping screws.
    All the drill holes and taps and bolts have to be the right sizes for it to work properly. So get these from a decent supplier who know what they are selling you.
  5. mikejoiner
    mikejoiner Member
    hilti gun , hilti nails and black caps .
  6. chip32
    chip32 New Member
    i agree whith mike joiner. hilti gun , nails and black caps chip
  7. jasonb
    jasonb New Member
    Mike & chip the OP asked for methods OTHER than using a gun
  8. sandynkev
    sandynkev New Member
    wot load will the timbers be taking
  9. dirtydeeds
    dirtydeeds New Member
    for a single one off relativly short steel beam
    if the loads are entirly vertical just use PU glue
    if the loads cant be guranteed to be entirly vertical coach bolt it to the beam
  10. redrobh
    redrobh New Member
    Thanks for comments.
    The beam is to replace supporting wall (spec'd by engineer) the timber is to fix joist hangers to.
  11. mack4
    mack4 New Member
    It would be best to use coach bolts if you are going to hang joists and flooring from the attached timber.
  12. malkie129
    malkie129 Well-Known Member
    I agree with most of the previous posters. If the timber is on top of the RSJ, then you only need to retain it in the shear plane. It's certainly not worth using self-tappers (only good into thin sheet metal) or tapping threads. Just use nuts & bolts or coach bolts....The choice is yours. As for adhesives, I don't know enough about them to offer an opinion. Malkie :)
  13. dirtydeeds
    joist hangers confirms the use of coach bolts
  14. redrobh
    redrobh New Member
    Great, thanks for the help.
