Hi Guys, quick question, building a porch and was wondering whether a depth of 1 mtr is enough and if 3 foot deep of concrete and 2 foot wide is too much...any suggestions. Cheers AW
are you planning on filling the trench? it will certainly be strong enough, 150mm depth will be enough.
Hi BC, Not sure what you mean by filling the trench? My plan was to dig down 1 mtr, fill with concrete 3 ft deep and brick up from that...Are you say that 150mm of concrete is enough. Thanks Will
Built a two storey detached house 3000 sq ft, engineer calculated the footings ( after test digging the site ) 150 mm concrete, no steel . Building control came out after pouring, foundations depend on soil types and weather soil is virgin .
your telling this guy to dig down 6 inch 150mm , then pour conc to level then build on it ??????????????????????? What fucik#mg planet you on ????
I think there may be a misunderstanding here. There are two depths being referred to. One is the depth of the trench, the other is the depth of concrete.
er yes, he said dig a 1m deep trench and put 3 ft (900mm) concrete in it, I meant its a waste to trench fill and to use 150mm concrete, in a 2 ft wide trench at least 1m deep.
ok bc ,I see what you mean now I do many conservatories and porches , I get a team in to do the building work . Ive always dug out 1000mm and mass filled to 3/4 courses below damp ,then start brickwork ,are you saying I only need to pour 150mm then start the brickwork I cannot see the advantage in this ,Time,cost to bring brick upto damp confussed !!!!
You only need 150mm of concrete but it many cases it's cheaper and easier to fill the trench. In this area, where you hit solid limestone as shallow as 6 inches deep, it isn't always possible to dig nice clean trenches as in clay for trenchfill, so I use a strip foundation then build up in blocks.
