Can a Franke kitchen sink with integrated clips be removed from a kitchen work surface. The hole is ~2mm too tight in depth, leading to a poor sink fit on one end. I would like to remove the sink, correct the width of the hole and refit the drop in sink. I have been unable to locate details on how to remove the sink on the web.
Only way I have found is to get underneath the sink and slowly prize the clips with a flat piece of metal but be careful cause when it pops out it will most likely rip the laminate off the top of the worktop
