Just wondering if anyone knew the correct way to put a franke sink tap hole blank plate on. The instructions dont metion it. Basically I have 3 pieces to it. Plastic screw bit (for underneath the sink), stainless steel circle tap hole cover (for above sink). There is also a foam pad... which side would this sit on? Many thanks.. the website is similarly helpful than the 2 diagram instructions!
I pretty sure thats all the parts as they were in a sealed bag. Thanks andy ill have a go with it ontop, was just wondering if.the foam would attract mould and the like as it'll raise the circle plate.
Any way you like. By the time an overflowing sink gets to that blanking disc water will be flooding all over the place.
The foam should compress to nearly nothing, and may be just less diameter than the plate. Mr. HandyAndy - Really
