I've just been trying to fit a new handle on my fridge. One of the screws won't tighten - obviously a fault on the door side. What can I do?
So is the thread stripped or is the threaded hole rotating? Often it is a nut/flange welded to the back of the very thin door panel, or a spire nut (a sort of clip) slid onto a lip of metal.
All I can say is that there seems to be a white plasticky presence behind the thin metal of the door. I hope you can see something from the pics - the double holes are okay - it's the single one - the perimeter is raised out - maybe I over-tightened.
Maybe the screws are different lengths perhaps the screw in the single hole has "bottomed out" by hitting the end and caused the damage. Hard to think of a solution where you have flimsy plastic threads, at least two are holding, any chance of finding a screw about the same size with a coarser thread that might bite in the plastic?
Gummo, that picture of the single screwhole seems to show it has been turned inside-out? Ie - the sides of the hole have been pulled so's they are now above the surface - if you run your finger along it, you'll feel it as a raised bump instead of a hollow? If which case it looks as tho' the screw has been over-tightened at some point, or has bottomed out as suggested above, or the handle has just been pulled on very firmly! So, if it's a simple case of the hole being pulled 'out', then get a screw/nail or whatever with a head that's just larger than that hole, hold it against the hole (overlapping it) and tap it gently inwards a wee bit - just below surface level. That might be enough for the proper screw to grip again, but if it isn't then just make up a drop of epoxy adhesive ('Araldite') and smear some on the screw thread before inserting. Do it up until it sits nicely tight but before it 'strips' again. Leave to set. Or, look for a slightly thicker screw. Cut a longer one down size if needed. (Most screws are very hard, but you can 'nick' them with decent side cutters, and they'll then snap cleanly if bent.)
A bit more work but you may be able to take the door apart to access the inside of the door panel Turn fridge off, remove door (usually straight forward as most are reversable) and remove door seal. Inner plastic door panel may be held with a few screws or clips and remove this Door will have some form of insulating material inside, possible polystyrene so remove this Threads on fixing holes have probably been stripped so you could use a nut and bolt to secure handle. Use a shake proof washer or Loctite on the thread as you don't want it coming loose in the future Good luck
Good point - lots of modern fridges are very easy to dismantle like that. Check the rubber seal around the door perimeter - see if it's just a case of pulling the seal away to free the door inner panel. Might not even have to remove the actual door from the fridge. But don't damage the seal.
Er, what's in the fridge by the way? Some home-made carrot cake, perhaps? Lemon tart? And, where do you live?
I've got sprouts in my fridge Phil We love em and eat them all year round (when available, fresh not frozen) And no they don't make me fart - well no more than anything else does !
