I need install new supply to consumer unit from meter. it is currently supplied by 10mm2 T&E, I will be installing 25mm 2 core SWA and seperate 16mm earcth cable. the run is around 22m. what is the situation with fitting a 80A fused isolator. do the electricty suppler require a fused isolator if the tails are or 3m in lentgh (i seem to think this is the case)
do electricty suppliers require a fused isolator fitted if run of cable to consumer unit is over 3m in length.
Answer is yes , but exact length dependant on suppliers, 3 mtrs is usual max, in practice switch fuse would be very near meter so tails would only be short.Hope that helps.
If you know the type of fuse and rating of the one in the cut out then and you can make sure your Zs is within limits at the end of the run you can just fit an isolator at the start of the run. If you put in a switch fuse with the same rating fuse as the cut out then all you end up with is two fuses of the same rating in series. Imo your just making things more complicated than they need to be. And yes I've done it (with runs longer than 3m) and no the Rec Police have never been round to bollix me.
Your still not explaining WHY you would need to fit a second fuse in series with the cutout if the requirements of 7671 can be met, ie Max Zs, volt drop etc. That's nothing to do with experience, that's just hiding behind the fact you can't explain why. If anything two fuses of the same rating are deterimental to 7671 as it doesn't take account of discrimation.
It's because of the length of the "tails" (swa) Col. Apparently most DNO's require this for tails over a certain length.
Sen we have been over and over this. One one has yet managed to produce any proof that this is the case. Every time I've asked the rec about it they just say "what you do after the meter is up to you". Recently I had the rec come out to pull the cut out to fit an isolator and explained what I planned (ie SWA run / move cu with cut out fuse providing protection) and she (yup SHE) just shrugged her shoulders and said something like "it will be better than the ****** 1970's cu that's there now".
yes, i think this came up a few months ago and someone linked to ukpn/western powers guide on supply intakes
thanks for the answers lads, my thoughts are the same as coloumb. why have two 80A fuses in series. I made a few phone calls today regarding this to northern power grid, meter plus etc etc did not get a definitive answer after speaking to about 5 different people, (most were just call handlers not technical dept.) I ran in the 25mm SWA and seperate 16mm earth today, I will terminate SWA into galv box and the wire into existing 100 DP switch
hi col, i seem to recall the attachments from the power distributors said something to the effect that past 3 metres isnt covered by their service fuse. i am on the dog at the moment but will try and find them when i get to the PC.
I found them and they don't. They say you can fit an isolator. Tbh I really don't understand why everyone is having such a baby over this. It's like the service fuse has some kind of sacred power that it won't behave just like any kind of normal fuse. I mean why not fit two consumber units? Or two fcu units? No one would. Anyway, what happens if the supplier changes? BG might say OK, but nPower might want less than 3m. So what happens? They come round and condemn the supply? Every time I've called the supplier all they say is everything beyond the meter is nowt to do with them. They are not interested and do not care how long the tails are.
The only issue I can see is the fault current would be traveling through their metering equipment, anyone know what the safe PFC is on a credit meter. If there was a fault I would prefer it to blow my fuse than the service fuse, I have always fitted an 80A switch fuse if I have ran in 25mm SWA, usually the cut out is 100A nowadays.
Peter, the fault current would run through the meter IF the fault happened on load side of the meter no mater how long the meter tails or if it fed a switch fuse. In fact, the fault current would be less the further away the fault happened. I would presume the cut out fuse would take care of this as all the equipment down stream from it would need to be rated high enough to take it, this would include the cut out, the meter as well as the consumer unit. You just need to make sure you don't exceed the Max Zs of the fuse in the cut out. Most are rated at 16ka I believe, with most mcbs being rated around 8ka. There would be no problem with fitting a 80 sw for a 100a cut out as discrimination is achieved, but if it was an 80a cu with an 80 switch fuse, my guess would be that, in a fault, both the fuses would blow at the same time, or it's 50/50 as to which one would go first, so I can't see any advantage to fitting two fuses in series.
Also looking at the pre-arc I2t time for bs88 and bs1361 fuses compared to the total I2t time the discrimation on a 100 to 80 amp fuse looks marginal, ie 2 or 3 1000'sth of a second.
