Good Quality Crimps
Discussion in 'Electricians' Talk' started by pcspike, Jan 4, 2014.
  1. pcspike
    pcspike Member
    Can anyone recommend a good brand of insulated crimps for butt jointing (that doesn’t come apart). I’ve read that SWA crimps are good but unable to find a supplier online that sells relatively small quantities.
  2. Sean_ork
    Sean_ork Screwfix Select
    CPC sell good quality crimps (AMP) in small quantities - but if you are able to pull the wire out afterwards it may well be the tool that's not doing it's job
  3. unphased
    unphased Screwfix Select
    Or the tool doing the job :p (only kidding).
  4. pcspike
    pcspike Member
    Thanks Sean,
    I should have said that it is not my experience that they have come apart it is what I have read and I’m wanting to avoid getting the same results by asking those who have had experience using quality ones such as yourself. The ratchet CK pliers that I’m getting should be up to the job.
    Had a quick look on CPC at ‘amps crimps’ but couldn’t see what I wanted there. I need the blue for 2.5mm two core and earth.
  5. unphased
  6. pcspike
    pcspike Member
  7. Sean_ork
    these ?
    http://cpc.farnell.com/pro-power/st...ssellid=CN11407&crosssell=true&in_merch=true&
  8. pcspike
    pcspike Member
  9. JP.
    JP. Screwfix Select
  10. pcspike
    pcspike Member
  11. pcspike
    pcspike Member
    JP.
    I’m going to have to extend the wiring to a few of my kitchen sockets when I fit my new kitchen because we have decided to go for splashback panel rather than tiling. The panelling is quite thick and the wiring to some of the sockets are not going to reach. Would solder and heatshrink be legal in this case?
  12. seneca
    seneca Screwfix Select
    Yes but you'll need 2 layers of heat shrink if the joints won't be whithin an enclosure.
  13. JP.
    JP. Screwfix Select
    Concur Sen - maybe also wrap the whole lot with gaffer tape (neatly and tight) to finish off? Sort of overlap onto the cable sheath when binding if possible? If not then wrap with insulating tape and cable tie the wrap both ends to prevent ''unfurling''
  14. unphased
    I don't know of anyone who would even contemplate soldered joints. Crimps and Wagos are by far the best way to go.
  15. pcspike
    pcspike Member
    Would you use butt crimps or parallel splice in this case?
  16. unphased
    I think generally, yes, I use butt splice which is a straight end-to-end in-line splice.
    Regards
  17. Lectrician
    Lectrician Screwfix Select
    Not exactly ideal day in day out....
  18. mr reflex
    mr reflex Member
    Always tend to think solder and heat shrink are more for auto electrics.
  19. pcspike
    pcspike Member
    Many thanks for that. As it happens I also ordered some Wagos last week too just to experiment with, they seem an ideal option but I wonder about the amount of space they will take up where a lot of wires are involved but at the price that they are they are worth a try.
    Regards Spike
  20. stateit
    stateit Well-Known Member
