Just bought this 11tpi and it's doin my heed in. It binds when cutting 2x1, anything thicker than 1/2". The wood is dry good quality par softwood. I'm no cabinetmaker but I've had quite a few saws and NONE does this at all. Bought the FatMax to replace a finecut Bahco - now blunt due to cutting nails!. Sawing a bit of wood isn't exactly rocket science, so what's up? Anyone out there using this saw? Thanks.
If it just random 2" x 1" sawn cut timber, I recon your Using too fine a pitch on the fat max, 11tpi is more suited to thinner denser timber.
Never been a fan of Stanley saws but it shouldn't bind. Try sawing at a shallower angle on a solid surface and rub the blade with candle wax.
Hi,that's interesting,as i recently got me a 3 pack of cheapo stanley saws... I dont like them! They tend to "bind" if i saw too hard, by bending too easily,as the steel blade seems to be thinner than normal. As joiner said, some candle wax will help
I was going to mention candle wax, but thought I'd let a real chippie say it. I'll stick with my trusty Bahco....As an aside, I have a S&J Preditor saw with a built-in lazer ! Why? I really don't know, apart from the fact at only a fiver, it was cheaper in B&Q that the ones without. I've never used the lazer, but it's an 11 tpi saw and cuts ply sheets really well.
Forget messing about with candle wax and use the right saw, 11 tpi is perfect for sheet material, for general cutting of softwood you need a 7 tpi saw, it is 2015 nearly not the 1950s where one saw had to do it all.
You wander offline just a tad with a finetooth, it'll bind as you try to straighten it! Mr. HandyAndy - Really
I dont buy stanley saws as like others have said have never heard a good word about them i always buy Bahco saws or Irwin Jack saws never had a problem with either brand its just whats cheaper in the merchants at the time
Anyone else thought that Stanley's quality has gone down hill? Not a patch on the old Stanley tools. At one time you thought: "Stanley, must be good", but now, much of a muchness. I've got quite a few old Stanley tools,still going strong, but the modern ones, I really couldn't be *with. Edited by Screwfix Peter due to language
In those days, most carpenters would have a crosscut saw and a rip saw (and possibly a tenon saw as well) It's nowadays we have a hardpoint saw that has to "do it all"
A 7tpi saw will cover a vast range of general cutting jobs, in all types of timber and plastics if needed, this is a general saw, if you are doing a more specific detailed job, then your will need a saw suited for that job.
Still got the old Disston saws though would never dream of using them now, so heavy and cumbersome. Rip, Crosscut, Panel, Tenon and Dovetailsaws, ranging between 4 and 18tpi, maybe a museum would be interested Still use lots of different saws for different applications. Remember the first Lance tooth saws that came out? There wasn't a joiner in the land who didn't need stitches after using them. Hard Points, you've never had it so good.
For the time and cost of having a handsaw sharpened (either by yourself or a saw doctor) your better off buying a hardpoint saw. I still have my saw set, somewhere in the house. (been that long since I used it, a saw would be back from the saw doc , before I found it)
I once knew a guy who used a chainsaw for EVERYTHING!!...i even caught him making some delicate alterations to built-in cupboards in his caravan! Lovely job,i said,kinda,erm...rustic
Ah! hand sawing I remember it well, what we need is more power! You do forget just how tedious it was to rip down some timber or cut endless numbers of bits only to find they were not quite all the same Must say I seldom do a hand job now, or perhaps should I re-phrase that
I became very reliant on power saws especially my trusty jigsaw,and forgot how quick a hand saw can be...dont have to plug it in or charge a battery,no setting up or replacing blades.just pick it up,use,and chuck it away when dull. Nowt wrong with the occasional hand(saw)job
Most of my tools are stanley fatmax and apart from a naff miter box i bought i have had no problems with my stanley tools, on a slightly different note used my Bahco handsaw to butcher the leg off of a frozen lamb (late christmas bonus from a customer) the hacksaw kept pinching hahahaha
