Are u sure its fine im scared now, i have it drying on wall over night and tomorrow i will start again insulating thermal roll the other thing they had in the shop was like a cement polyfilla type for covings ceramic etc
"cement polyfilla type for covings ceramic etc" You are kidding? The other one you mentioned - the thicker wall paste for 'blown' coverings etc - should be ok, if you are not going to get the 'proper' stuff.
Well I did all this it seemed it was working but the bottom about 2ft up is coming away still and the other wall on the other side is similar on that wall the adhesive is slowly dripping down not sure if its the fact I was putting this on a insulation I did everything asked and the bottom of it 2ft up is coming away The wall on the other side is similar but the adhesive is slowly dripping out unless I use a litre of loctite I just give up its a nightmare
The coldest part of the wall is at the bottom, at this time of year it could take a little longer to dry, you are clearly doing something wrong.
