Heating Circuit Diagram
Discussion in 'Plumbers' Talk' started by deanalewis, Feb 7, 2014.
  1. deanalewis
    deanalewis Member
    I've asked this question in both Plumbing and Electrical as it falls technically under the remit of both.
    I have presently mounted on my wall
    A Danfoss TS715si Electronic Single Channel Timeswitch
    I have bought a
    Danfoss RET230 Electronic Thermostat.
    Basically I want my setup to perform like this.
    If Timer Is On AND Thermostat Is Calling For Heat Then
    Turn Boiler On.
    Or Else
    // Keep Boiler Off.
    I provide a few diagrams to show you how I think it should work. I think Configuration 1 would be correct but I just want to run it by a few people who do this for a living just to confirm.
    I know that I should have bought a Programmer but ultimately I like the challenge and the idea of a manual thermostat than a digital one.
  2. Devil's Advocate
    Devil's Advocate Well-Known Member
    (See other thread :))
  3. Sunseeker
    Sunseeker New Member
    Config 1 is correct
  4. wiggy
    wiggy Well-Known Member
    not so sure
  5. Devil's Advocate
    I'm sure.
    That it isn't :p
  6. Sean_ork
    Sean_ork Screwfix Select
    it's fine
    assuming the neutral to the boiler has been omitted for clarity
  7. deanalewis
    deanalewis Member
    Worked like a charm folks, Thanks for all your help
