Evening. Looking for some advice in how to assemble a 2 piece Wren breakfast bar. Have been assembling the units myself but stumped in how to assemble the breakfast bar. (See photo) - It comes in 2 large pieces with no obvious fittings. - One end overlaps a 300mm base unit but would like to know how I secure the 2 pieces at a 90 degree angle and how to secure to the floor. Don't want it falling apart with a firm nudge. Many thanks in advance
If i was fitting that i would use Biscuits and PVA to join the vertical to the horizontal. If you don't want to see L brackets on the floor ? I would use 2 100mmx10mm steel rods drilled 50mm into both the base of the vertical worktop and the floor. Weight and gravity plus any floor you lay afterwards will then keep it in position.
