a customer of mine has a damaged handle on her pvc door. easy little job i thought until i removed handle and found it has 2 spindles, 1 so door can be opened when unlocked from inside and the other so it cannot be opened from outside when unlocked. does anyone know where i can get hold of a pair of these handles, i have all measurments for existing handles. Any help would be appreciated. cheers Tom
hi mate, it is called a split spindle.wont matter about the type of handle/lever as only the spindle is the differance to the lever mechanism,ie,if you just put a ordinary spindle in it just becomes a ordinary lock. your only concern is the holes in the lever match up. hope this helps.
Hi, I've used these in the past http://www.upvcdoorhandles.co.uk/ Have a good range with template guides for matching.
