hi there, I have a loose handle on a a "juliet balcony" door in my apartment. Sorry but not sure if thats the right term for the door - it can pivot horizontally or vertically (along the base). You can view a video of the looseness here... https://drive.google.com/open?id=0B6b4OEFKzWLnMGFUc3pUQlBwMEU I was hoping I could take the handle off and tighten it up in someway but I can't work out how to take the handle off. The only screw I can find is on the inside of the handle (its an allen grub screw - see picture) there are no screws inside the frame or outside. I've taken this out but still can't see how to remove the handle. Can anyone suggest how this is taken off? Cheers for any advice Alg
Normally, you'd remove that grub screw, and pull the handle straight off. Then the next cover prised off would have screws holding it to the frame/lock. Mr. HandyAndy - Really
