So, I need to fix a door into a frame that is wider than the door is and I want to hide the fixings. For example, the opening is the height of the door, and three times the width. The door is glazed and will only form a partial divider for a room so I need to secure it into the frame using hidden fixings but it needs to be secure. I thought about double ended screws or perhaps flush mount brackets to slot the door into the frame and secure it. Anyone got any better suggestions?
2 pins and 2 holes in the wall side. Slide it in. 2 flush bolts(top and bottom) in the open side. Lock into position. Mr. HandyAndy - Really
Er right so....er.....are you using the door not as a door but as a fixed panel ? If the opening is 3 times width of door, is door going in the middle or to one side ? Is there going to be a frame around both sides and head of door ? Could ask so many more questions ..........like er....that name....who told you that you was Ace at 'it' ???
Can you router out a square 20mm x 20mm continuous recess out of the door at the top and bottom and securely fix a batten of say 18*18mm hardwood or whatever it takes to the floor and frame head and slide the door in to the runners. Skew screw a fixing and the ends top and bottom.
