the pressure on my 105e baxi boiler has jumped up to 3.5 bar i have blead the rads to drop down this pressure but an hour later the pressure was back up again any ideas on wot is causing this
filling loop passing or plate heat exchanger kaput,possibly could be exp vessel,when was it last serviced,these three things are the easiest to start with.
the pressure on my 105e baxi boiler has jumped up to 3.5 bar i have blead the rads to drop down this s pressure but an hour later the pressure was back up again any ideas on wot is causing this Global warming.
Thanks bleve sorted it today was the filling loop a valve failed only £2.60 for a new part also i gave it its first service since i put it in 6 years ago such an easy boiler to work on
