Hole in a wall for Extractor fan
Discussion in 'Builders' Talk' started by crackers, Feb 28, 2011.
  1. crackers
    crackers New Member
    Hi
    I have recently purchased an Xpelair extractor fan and it suggests a hole of 184 mm. I cannot find a core drill of that size from hire centres. Are there any suggestions for achieving this hole size, or is it down to manual hammer and chissel, or partial core then hammer. Does a core drill this size exist anyway?
    I would appreciate help on this one.
    Many thanks
  2. jj build
    jj build New Member
    you could use a small long sds bit and drill the shape of the hole, with the small holes as close as posible and then nock it out. most extractors use a 100mm hole
  3. Does it really have to be that size, crackers? Is the ducting length just going to be a wall thickness? Can't you just drill and fit a 100mm duct and then 'mate' your extractor to it?
  4. Captain Leaky
    Captain Leaky New Member
    These big fans need big ducting, I always stitch drill around then chisel out, not much worse than core drilling to be honest.
  5. glnta
    glnta Member
    HEAR HEAR, DRILL THEN HAMMER AND CHISEL, NEVER USED A CORE DRILL FOR LARGE HOLES.
