Hot Water
Discussion in 'Plumbers' Talk' started by MJ, Oct 23, 2003.
  1. MJ
    MJ New Member
    Please advice: the central heating has been out of order for a few years, and I want to install a thermostat to the water cylinder in order to have hot water, how is that done and what would be the cost?
  2. Nigel
    Nigel New Member
    You need to install one of these 12461 [screwfix part number].
    Turn off water to cylinder, remove plug [special spanner required] and install heating element, size and wattage will dictate how much water is heated and speed it is heated.You will need a local power supply to power the element, size again dictated by wattage used.
