I was given a stanley hand plane so I've watched loads of youtube videos on how to get the plane ready for use but when I tried lapping the back and sharpening the blade I couldn't get a sharp edge so I've bought a new plane iron to try again. When I lap the back what grit sandpaper should I start with as I've seen some use as low as 80 grit but other people have said they wouldn't go any lower than 400 grit. The problem I see is when you watch the youtube videos they only use a plane iron or chisel that they wouldn't use in a shop so it doesn't matter if they used 80 grit sandpaper.
You cannot do better than Paul sellers for this kind of thing; This one is just over an hour long and covers restoring a plane from start to finish. Regards, Cando
And for what it's worth dealing with the blade/iron starts just over half an hour in. You could also watch his chisel sharpening video which gives a good demo of papers used to deal with the backs. Regards, Cando
I've already watched the video you posted and also his chisel sharpening video . When he lapped the back of the chisel and did the bevel he said that still doesn't feel sharp to me then he went and used his diamond stones. I used the same grit wet and dry as paul sellers and I couldn't get a sharp plane iron. I've read on forums where people have only gone to 1200 grit wet and dry and they have had a sharp chisel and plane blades.
Chris tribe used 80 grit to lap a new chisel. I used 80 grit on a old chisel and it put a deep scratch on the chisel due to the grit not all the same size.
Plane blades get ground at 25 degrees then sharpened at 30 degrees (usually) I always use a diamond sharpener to sharpen my plane and chisel blades. Don't forget to back them off. Plane blades can be sharpened many times before they need reground though.
When I was given the plane it wouldn't cut butter and it looks like it's only been sharpened to 25 degrees. I don't know when the bevel would need to be reground to 25 degrees so maybe I should of done this first as I don't know how many times the blade was sharpened. What diamond sharpener do you use because I got a 3 eze lap diamond stones but I find the super fine (1200 grit) is to course and leaves lines in the bevel.
That should not be happening! If the stones are brand new they can take a little time to "bed in", but even new the 1200 shouldn't be leaving lines! Regards Cando
