How much to hang a door
Discussion in 'Carpenters' Talk' started by limestone, May 15, 2015.
  1. mr moose
    mr moose Screwfix Select
    Well I would expect to take longer than a day to hang a front door, unless it was a small one with not many locks etc, but if your talking about buying it, buying all the hardware for it ,cutting to size ,three hinges, cutting the letter box, hinge protector bolts, door knob ,knocker, letterplate , numbers for door, draught proofing, mortice lock, Chub lock, peephole and security chain. Then over a days work in my book!
  2. mr moose
    Not forgetting getting the old door off as well!
  3. chippie244
    chippie244 Super Member
    Never taken longer than a day for a front door, it's got to be left hung and secure at the end of the day so why would you go back.
    seen it all before likes this.
  4. mr moose
    Well I am probably just slower than you, I like to take my time and do a good job (I am sure you do too).The way I do it is get everything ready, buying, cutting to size, hardware etc, then actually fit the next day.
  5. chippie244
    I think you need to buy a Festool plunge saw. :):)
  6. mr moose
    I all ready have!:) Also don't forget the weather bar as well.
    Perhaps its just that I am only 14" tall have paws for hands, my heads full of foam and nose and antlers keep on getting in the way.:D:D:D
  7. chippie244
    Are you running the economy as well?
  8. metrokitchens
    metrokitchens Screwfix Select
    Should only take a day. Unless it is a restoration job or unusual in size, or on the 30th floor and you have to do all your cutting on the ground. ( I have had that situation).
  9. goldenboy
    goldenboy Super Member
    A front door is a job and knock day in that you cannot leave until its done. I remember a nightmarish door hang in Liverpool with a faulty yale and a midnight finish!
  10. seen it all before
    seen it all before Active Member
    16 hours on a door because of a faulty yale lock. Would have been quicker to go buy a new one. Personally I've never spent more than a day on a front door.
  11. Mr. Handyandy
    Mr. Handyandy Screwfix Select
    ..and so the pykies get the job again, and do it for 70 quid.
    Mr. HandyAndy - Really
  12. Big Dunk
    Big Dunk Active Member
    Yep people in Liverpool turn their noses up at me when I tell them £150 to fit and hang a front door.
  13. chippie244
    Do £150 of work and then leave them to stay up all night fighting the scallies off:cool::cool:
  14. Big Dunk
    Needless to say I don't hang many Front doors anymore ;)
  15. chippie244
    I avoid them as much as possible.
  16. mr moose
    Perhaps you should charge a bit more for them then eh Chippie!;)
    Phil the Paver likes this.
  17. chippie244
    I charge £200 for hang, night latch and mortice lock, anything after that is negotiable.
  18. DIYStorm
    DIYStorm New Member
    Hi, I found this thread which relates to my query.
    What is today's going rate to hang a new front door? It's to replace an existing UPVC door with a timber one and a new frame will need fitting too. The new door will need shaping to be hung in the opening.
    I've had a quote but not having any experience on door fitting prices I've no idea what is reasonable either...
    Appreciate your advice.
  19. Astramax
    Astramax Super Member
    What was your quote? Start to finish including materials could well be in the area of 2k +
  20. DIYStorm
    DIYStorm New Member
    I’ve been quoted £780 for the whole job (remove existing frame, supply & install new wooden frame, hang new door that we have and make areas good once completed)
    Is this figure about right?
    Thanks in advance
