How to cure Water Hammer (on combi system)?
Discussion in 'Plumbers' Talk' started by dan1, Jan 27, 2012.
  1. dan1
    dan1 New Member
    Hi - recently moved into an old house.
    When we first moved in we could hear a bad water hammer (clanging) on the pipes upstairs whenever we turned off the taps on the sink downstairs - it was louder the quicker you turned off the taps - it didn't occur anywhere else.
    However, we had a combi boiler fitted soon after, and this seemed to co-incide with the problem disappearing. It has all been quiet for a year - until now.
    We have just replaced the bathroom suite. Now when turning off any of the new taps on the shower (lever type), bath (1/4 turn), sink, flushing the toilet (when it finishes refilling) and when using the washing machine, the water hammer is back with avengance.
    We have secured the pipework with clips in the bathroom floor, and, to the extent that is possible, under the boards upstairs in the hallway. The clanging is so bad that we could even feel the pipework move right back to the front door by the stopcock where it enters the house.
    So, my question(s).
    I've read a bit about Water Hammer (shock) Arrestors
         1 - Can they be fitted with a combi boiler system?
         2 - Can anyone recommend one? - might this work for example https://www.plumbcenter.co.uk/en/rwc-1-2-water-shock-arrestor-82361?top_category=18233
    I have also read that changing the main stop cock to a lever type can help - why would this be?
    Thanks in advance for your help!
  2. Hi Dan.
    Hammer is caused by a moving part shuddering under the flow of water - that is usually a washer-operated device such as found in a mains stopcock. Often the overriding cause is high mains water pressure - any idea what your water mains pressure is like - does the water come out with considerable force?
    Anyways, the cure is down to the cause. Sometimes it can be a matter of securing the vibrating pipework - if happens that that was all that was allowing it to happen. Better is to find the vibrating component - such as the offending washer. So if you fancy trying to swap your mains stopcock with a ball-lever type then that could well cure it.
    (From your description, it seems clear that it isn't ONE single thing that can trigger it, so we can - I think - discount it being caused by one loose washer or part in a tap or toilet in the house - it must be down to an independent part that's common to all the water system - so the mains cock is again likely.)
    Will a shock arrester fix it? Very likely. Can it be used with a combi system? I believe so - I can''t see why not.
    If the 'cause' is very high mains pressure, then another solution could be to fit a PRV (pressure reducing valve) to lower the mains pressure to, say, 3 to 4 bar.
    Things to try - turn the mains stopcock off, and then open it up just, say, 2 full turns. See it that makes a difference. Or, get your system vibrating nicely, and then slowly shut off the mains cock - see what it feels like as you do this; can you feel the vibe? Try and get a sense of whether it's this stopcock that's at fault.
  3. graceland
    graceland New Member
    yes i thought a shock arrester almost HAD to be put in with a combi ?
  4. HOTDOG ø
    HOTDOG ø Active Member
    Twaddle! It wont hurt to fit one but it is only masking the cause.
  5. graceland
    I didnt say it was causing it *?
    Message was edited by: Screwfix Moderator
  6. Supra
    Supra Member
    We've also got a problem with water hammer, the vibration actually travels through the shared water main into the house next door.
    These quarter turn taps aren't good as they shut of the water so quickly, the same goes for these compact plastic float valves in the cistern.
    Obviously if you turn off the quarter turn taps slowly you won't get the water hammer.
    I replaced the cistern float valve with the old fashion brass valve and arm as they're much better in reducing the hammering . You can get them for high and low pressure (low pressure if you have a cold water tank).
    We tried a shock arrestor like the one in your link, it did work a little but the noice was still there. We bought it at Toolstation, not stocked anymore but they're selling a different version which works on the same principles. It's called a "Mini-Rester". The bottom one is made by Sioux Chief, not sure about the top one.
    You could install as many as you like on the cold water pipe (close to the offending taps/toilet etc as possible).
    I made a similar device from a vertical copper pipe which traps the air so it cushions the vibration but it has to be drained every so often unlike the  "Mini-Rester" which is maintenance free.
  7. It's because the pipe work isn't clipped correctly
  8. petertheplumber
    petertheplumber New Member
    All pies should be supported at regular intervals 15mm every meter of length, but few plumbers do it since it takes longer to do the job and diy are the worst offenders, clip the pipes or live with it.
  9. diymostthings
    diymostthings Well-Known Member
    ".....and diy are the worst offenders,...." I resent that statement Peter!! a lot of DIYers take care and pride in there work and try to keep to the latest regs. They havn't got time/money restraints like a pro, who needs to rush to make a living! Obviously there ARE DIYers who are careless but - I would argue that there are a lot of pros who are too. A quick look at the plumbing in new build might convince you.
    diymostthings
  10. petertheplumber
    May convince me. We are all entitled to our opinion and I have seen enough DIY mess up's to stand by what I said. End of.
  11. Crowsfoot
    Crowsfoot Well-Known Member
    100% agreement here Peter - did I tell you about the bath that was fitted over an old shower tray?
    The DIYer was too idle to knock out a new waste hole and on pulling out the bath plug it discharged into the shower tray beneath it !!
    All was well until the shower tray waste got blocked up with hair and flooded the bathroom !
    Tappy,
  12. petertheplumber
    That sounds about right Crowsfoot.
