I need to run a length of 32mm kitchen waste pipe. One end of the pipe is going to be buried under the floor, so I want to use a solvent fitting for that, but the other end needs to have push fit so that it can taken apart (push fit rather than compression due to lack of space). What's the best way to achieve that given that 32mm push fit fittings don't fit 32mm solvent weld pipe and vice versa?
