HI My boiler is showing ignition lock error on the lcd screen. I have reset it and it's still doing the same. I Have cleaned the condensate drain water too and reset it after. Still showing same error. Other gas appliances are working fine in the house. Also removed the ignition spark lead and inserted it again. Still not luck giving same error. What kind I do next to rectify the issue?
We had an ideal, gave trouble. Had repair after repair. Luckily covered by BG homecare. But that didnt solve the problem. Ended up getting a vailant. I think thats what you will have to do in the end.
