So were following on from another builder who screwed up the heights of a extension. The result of this is almost like two huge fascias. How could this be broken up? It looks terrible!
Rainwater hopper look bad aswell, exiting above the middle of what I presume is a window. As for the double fascia I presume the roof is a warm roof spec, this always looks deep, though looking at yours, it looks like the Windows could be higher eliminating the lower fascia.
There is a steel head going through unfortunately. And no its not a warm roof. It is just a bad design, that unless a lot more money is spent has to stay as it is
You could paint the lower fascia with the correct primer first to match the existing colour as seen on the property wall, this would give the illusion of reducing the fascia depth.
I would lower your eyes and watch out for the problems at ground level and at the side of the extension
No disrespect to the homeowner, but with the picture there are so many issues - instead of "spot the ball" it should be "spot the ball**k"
There is about a dozen faults /issues - excluding picky things like the cement being stored on the ground and the comical bit of trunking on the first fix socket.
Get a decent zinc installer and agree a detail https://www.google.co.uk/search?q=z...IBywKHX_vA5EQ_AUIsQEoAg#imgrc=D6g7nuXL43AzjM:
Im only doing the carpentry work but the builders ik doing it for are sooooo bad. Done studwork at a new build and the block wall was 80mm out of square! Had to square it off with another stud wall otherwise you would see it in the tiles. The steel frame on this job is 20mm out of upright over a 1200 level and the windows were measured to the latgest point haha I was thinking zinc. Not really my personal job but it makes me feel bad when following on from monkeys
I suspect that Astra's and possibly Simon's (if needed) solutions are the only really practical ones without going to unreasonable expense. Ie - paint the lower fascia the house colour. It should be possible to tell what this would look like with a bit of photo-shopping? At least once the windows are in.
