Thinking of having the above installed,but all the kit i have viewed seems to come with a 3 pin plug to power it up. i want to be able to pull the cord switch and hey presto my 4 recessed lights and the led's all come on together,then with the aid of the ir remote iam able to change the colour of the led display,how is this achieved ? Thanks
If the bath panel is screwed put the plug and socket under the bath.. feed the socket off a pull cord. Feed that off the lighting circuit or a fuse connection unit. Only issue is that the lights need to be zone 2 compliant to be installed in zone 2. Also you'd need to check the remote would work through the bath panel.
