My present 70:30 integrated f/f is broken. The doors of the replacement f/f I want to buy are about 20mm higher than those on the broken one. Will I need a new set of unit doors? If not, will the bottom of the unit doors line up with the other built in units? The measurements are: Old f/f: fridge 1010mm, freezer 620mm New f/f: fridge 1032mm,freezer 644mm Height of unit doors: fridge 1245mm, freezer 715mm
You normally get at 50/50 or 70/30 split when it comes to integrated fridge/freezers. If your fridge/freezer doors are slightly bigger than your current kitchen unit doors then you'll just need to adjust the fixings on the back of the unit door that allow you to attach it you your fridge freezer.
