Hi There I know there is already advice on here about plywood floor gaps - but I'm installing one which has very irregular, angled tiles. Similar to this temporary one I made for an art fair last year but more professionally done! http://static1.squarespace.com/stat...bd44eb8/1413791976135/floor2.jpg?format=1500w I'm using the following: - 8mm structural hardwood ply undersheeting - nailed to original floorboards with 10mm gap around outer edge. - 15/18mm structural hardwood ply tiles - pinned and glued to the undersheeting - emulsion & then plenty of coats of floor varnish My questions / quandaries are: - Because I'm pinning and gluing the tiles to the undersheeting - can I get away with no gap between tiles ? - Should I still be leaving 10mm around the outer edge of the floor as well as the undersheets - or can I get away with less ? Any constructive tips welcome! Thanks
