Really Mr HandyAndy? Why don't you try this yourself and make me a little video while you're at it so I can see exactly how it's done?
That is with the CT101Cs. If you use CT102Cs then the required cord grip is present. (All 4-pins have a cord grip also.)
Is it not like this? Can be removed, put on the cable, then replaced. Or just push the cable into it, in an upwards movement. Or is it not that kind of grip? Mr. HandyAndy - Really
Yeah Andy, that's the one! I don't think it can be removed. Pushing the cable into it is nigh on impossible, because there's not enough room for the tabs to expand. Eventually got a 1.5 in, but no way a 2.5 will go in. Try it.
Well give the cable a little squeeze with the pliers! And remember to push up as well as in. And if you are using 13A fuse, no benefit using 2.5mm cable. Mr. HandyAndy - Really
