Looks very nice did you do the hole saw way of fitting worktop bolts mite try that on some of my jobs cause the other way of per fitting together is a nite mare
Yes mate I did just marked out underneath where the little barrel bolt was going to sit & little bit of sealant on the edge & just nip up with the 10mm spanner just checking the alignment and remove the excess sealant , have to look very closely to see the join , I'm no kitchen fitter but pleased with the result & how easy that it was to do , well after I was pointed in the right direction from a few of the fellas on here !
Ha ha ta mate , not only pink but "glitter pink " @ that , little bits you mix in with the paint & advised to roll it on with a mini fookin roller , took about 5 coats before it looked anything & the old wonan was happy with it , now she wants a load of signs put up in there & said just bash a load of nails in the wall you can't make it up lol ! Looks like you like a bit of pink n all !
