First time owning a router. Where is the collect supposed to go? So that i can use the bit? The instructions are not very clear
Here where the pencil is pointing to Routers are very, very dangerous tools. TBH if you can't work this out then probably you should hold off from using it until you have watched some videos or taken some training
Wise words. And another danger is overtightening the collect & not installing cutter fully, the router is up there with circular saws /table saws for dangerous tools. AND regardless of the power tool unplug it, before making any adjustments to it.
Trend have a list of various routing courses around the Uk, covers basic through to advance user,will allow you to get the full benefits from your router & able to use it safely. http://www.trend-uk.com/en/UK/trend/content/content_handler.php?record_type=Courses Most likely other traing courses around the UK.
Axminister Tools runs some courses, but does depend on where you are in the country. http://www.axminsterskillcentre.co.uk/category/Routing-3.htm
There are many router couses around the UK, Yandles, Wealdens are just a couple. http://www.yandles.co.uk/about-yandles/32-routing-courses http://www.wealdentool.eu/rons_courses.html There are 2 & 3 day courses around as well, Peter Sefton Furniture School is one that runs them. https://woodworkersworkshop.co.uk/b...ourse_beginners_and_advanced_make_a_tool_tray Slightly wandering, but still router related, are Woodrat courses, the woodrat being a brilliant tool for the router, & takes routing to a whole new level. https://woodrat.com/courses/
