Large house combi v system boiler?
Discussion in 'Plumbers' Talk' started by Naesure, May 26, 2008.
  1. Naesure
    Naesure New Member
    Hi.
    I am upgrading central heating (at same time as kitchen / removing AGA etc) and I have a relatively large house, almost 30 years old, 5/6 bedrooms, 2 adults and 3 kids live there.
    My question is should I go for a combi boiler (Worcester Greenstar Highflow 440) or a system boiler? We have 3 showers, 4 toilets, only one bath in the house, I would say it is very rare that someone will be taking a bath at the same time as a shower. However it is very likely that someone will be taking a shower at the same time as someone else flushes the toilet / washing machine or dishwasher on / runs the hot water for dishes etc.
    I realise that the combi is easier to install, less hardware (no cylinder), I guess that cost wise the system boiler will be more expensive due to increased labour. However I am keen to get it right, I have heard that combi systems can provide interrupted flow (shower going cold when another toilet is flushed etc) and would be very interested to hear advice from professionals (other than my plumber) and related experiences. I have plenty of unused loft space (currently 2 cylinders in there!).
    All help greatly appreciated.
  2. tomplum
    tomplum Active Member
    i would advocate a unvented cylinder system, a combi would not be 'man' enought for a large house.
  3. HOTDOG ø
    HOTDOG ø Active Member
    Combi's are for flats and small houses with one bathroom. You would be a certifiable nutter if you put a combi in your house.
    A decent boiler + unvented cylinder will work beautifully.
  4. Water Systems
    Water Systems New Member
    Most definitely. A class act!
    The Highflow will do it. Flow and pressure robbing is due to poor installation. Renew the cold mains maintap to a full-bore and run a dedicated <u>22mm pipe</u> to the combi. Tee off at the maintap and have all other cold supplies off this leg - this can have a flow regulator in it to ensure this leg does not rob the combi leg. Just before the combi tee off the cold supplies to the showers. Any pressure fluctuations around the combi will be minimised on hot and cold and to the showers. Get <u>pressure balanced</u> shower mixers - combi compatible means nothing.
    Put a Magnaclean filter on the return to the combi.
    What is your mains pressure and flow in litres/min. This means a bucket filling at the kitchen tap with a stop watch.
    Plumbers hate combis with a vengeance as it takes needless cylinder fitting work away from them. So ignore them.
  5. tomplum
    you're wrong again WS, this plumber loves combi's i have one in my own home, but they are not good enough for big houses,and it would be folly to install one without the right advise,and the right advise is:- get a few plumbers round for advise and quotes, then make yer own mind up,,,
  6. tgs
    tgs New Member
    I think the first thing here is to see what your existing showers are giving you in terms of litres per minute.
    Stick a container underneath ( a bucket will do) the shower and turn on for ten seconds. Then measure how much water is in the bucket (pinch a measuring jug from the kitchen) and multiply by six. If your showers are gravity fed then the result will probably be about 6-8 litres per minute.
    Three showers will consume about 24 litres per minute. You need to see if the cold supply to the house will give at least this much. If not the combi is the wrong choice. If your cold supply passes this test then the combi needs to be able to supply at least 18 litres per minute of hot water at 55C to supply the 3 showers all at once in winter. This is a 50C rise in temp from an estimated cold supply coming in at 5C.
    If you have gotten this far and still think the combi is the one for you then ring up the manufacturer's technical helpline and ask which sort of mixer they prefer you to use. I have found the answer has always be a thermo mixer rather than a pressure balancing one. The requirements, for example, for the Mira Combiforce would never be met with one shower operating on the a powerful combi like the one you are considering.
    Once you have gone through the above then, by all means, come back to the forum and ask some more questions.
  7. bun the plumb
    bun the plumb New Member
    ethos boiler
  8. Water Systems
    The right advice is find out first before some plumbers come around and make them specify on your requirements, otherwise, as in 70% of cases, the least adequate solution, and that includes cost, will be installed.
    There are many combis around that can do two bathrooms without any fuss. The odd couple, can do three.
    Combis must be the first selection in a normal house with a rad circuit and decent mains pressure/flow.
    If you know about combis you would not be recommending expensive, potential bombs like unvented cylinders.
    BTW, combis <u>never</u> run out of hot water.
  9. doitall
    doitall New Member
    True Ws they never run out of hot water
    They just run out of water full stop.
    Anyone that considers a combi in this situation, has more money than sense.
  10. Water Systems
    per minute.
    Are you kidding? You measure the flow rate at the garden or kitchen tap
    Poor main pressure is not good for any mains fed system, and that includes those pathetic unvented cylinders plumbers make fortune fitting, too.
    balancing one.
    Since when do makers know anything outside their boiler's cases? You get a pressure balanced mixer!!!]/b]
    As the Highflow does around 20 litres/min it probably will.
    questions.
    It is better if don't answer :) Duh!
  11. Water Systems
    He has three showers and one bath!!!! He says the likelihood of all three being on is slim. The HighFlow is perfect.
    I would go for the Mikrofill Ethos, as this is high flow and will never run out hot water. And it can have a secondary circulation loop on it. Then no problems.
    BTW, the HighFlow is a two stage flowrate boiler. When the store is exhausted it reverts to around 13 litres/min. It NEVER runs out of hot water.
  12. Water Systems
    BTW, an unvented cylinder will struggle with three showers.
  13. doitall
    doitall New Member
    That enough for the bath now what
  14. doitall
    doitall New Member
    Not if the mains is up to it, it wouldn't.
    With a combi its 100% hot water, whereas an megaflow is 50-50 hot and cold.
    A sludge bucket and a large plate would be better than a combi.
  15. Dick Puller
    Dick Puller New Member
    BTW, combis never run out of hot water............Well, unless they break down, which they well Xmas day, so no heating or hot water..........Happy hunting!!!
    If you take the advice of that arzehole Water Systems and fit any kind of combi, fit an electric shower also. Then at least you & Santa will get a warm shower.
    Heatbank or thermal store anyone???!!!
    What's tartan & smells of ****??
    Water Systems's slippers!!!
  16. Water Systems
    probably will.
    20 litre min at 60C.
    Try running three showers and a bath from an unvented cylinder.
  17. tgs
    tgs New Member
    per minute.
    the
    how
    probably
    The point here is how much HOT water is required from the combi and that means measuring from the shower. I then suggested measuring the mains inlet flow rate. Read the posts first.
    combi
    they
    balancing one.
    mixer!!!
    DEFINITELY NOT!!!!!!! Pressure balanced shower valves are slower to operate and a lot of combis will produce an unsatisfactory shower. If you have several showers used together then you need a thermo mixer.
    one
    will.
    If the highflow puts out 20l/min the the chances are that it will not conform to the Combiforce requirements with one shower operating. Too much not too little.
    questions.
    Much better if you check your facts first. You have a habit of not doing this and, not for the first time, I have had to point out the obvious and glaring errors in your postings. Of course, you will not see the wood for the trees in this case either.
  18. Water Systems
    Tripe! 60C comes out of them. Do you bath in 60C?
  19. Water Systems
    Todger, you are making things up again. When did they let you out of the cells?
    break down, which
    Because you fit cheapo scrap!!!
    Todger, I am no Jocko. I wouldn't be seen dead in tartan. How is the Tammy? Still use it to wipe the joints.
    How much was the fine?
  20. Water Systems
    You measure the flowrate at the kitchen tap and fit mixers or pressure equalisers to suit.
    mixer!!!
    <u>You clearly haven't a clue.</u> The point about them is that they react within faction of a second while wax operated thermostatic mixers take many seconds. The different between being scalded or frozen.
    20 litres/min itprobably
    will.
    It does.
    It is better if you don't answer :) Duh!
    Once again..It is better if you don't answer :) Duh!
    And let out loose on the public. :( Wow!
