I'm building an outhouse in my garden and need to get power to it. Is there a tool I can hire (I'm imagining an electronic mole type thing...) that could lay the cable for me without having to dig a trench through the garden? Cheers James
There are moles but the hiring cost would be prohibitive to say the least I would imagine. If you use the linked properly, then you will have turfs left from the digging which you can reinstate. http://www.amazon.co.uk/dp/B0001GS0...m=A3P5ROKL5A1OLE&pf_rd_r=1JCWCZHTM7RVP439Q3AJ
Hi James , moling is always a good option that seems to always get over looked ! You may have to have a little search to find one to hire , but one of your local hire shops should be able to point you in the right direction . From what I have heard from customers , they have been offered them from £90 per day upwards to hire themselves . They are not electronic and work off compressed air , so make sure you get the whole kit including the marker post and aiming sights . To be honest the launch cradle is a bit gimmicky in my opinion and I can not even remember the last time we used them . As long as you are 110% sure that you have no other services in the line of the then you will not need to cat scan first , but if you can get hold of one it would be wise . And make sure you go in deep enough , as a rule of thumb I have found at least 10 to 12 times the circumference of your mole , or it will hunt for the surface within a few meters . And always meter mark your air line with tape before starting , so if the mole does go astray you have some chance of knowing where to dig and find it with just the one hole !
What the distance involved? Grundomat Moles seem to be most common for hire, & you need a large compressor. http://www.speedyservices.com/08_2500-h-mole-45mm Thought about using a micro excavator with 150mm bucket instead, will fit through a 760mm opening.
Grundomat are the best in my experience , they just seem to hold their course more accurately for some reason !?
Plenty of firms out there who offer moling service for residential places, might be easier than hiring.
I tend to agree with you , as we have 5 of them in total . But it is not the black art that some seem to think it is , as long as you have a bit of common sense , what could go wrong!
James, what distance are we talking about, and what sort of terrain - and ground cover? Any reason why you cannot chose a safe-ish route and just cut a slot using a spade?! Drop in some SWA - job done.
Sadly,some youngsters today don't how to use a spade. Neighbour here hired mini digger to dig 10metres of footings barely 300mm depth.
I'm not racist in the first instance. Saying, nobody ever heard of a black man being called racist for calling a black man a black man. Mr. HandyAndy - Really
Why do visualise you saying "Ooooh" with one hand on yer hip and t'other swatting a non-existent fly in front of you?
