Hi, I am looking for some advice. I have trawled the internet but with mixed results. I am looking at purchasing 60m2 of Reclaimed Solid Oak Flooring (22mm) from a local company who specialise in this. I plan to install it myself in my house, where I have just finished building a reasonable sized extension. The area I plan to lay the floor is around 2/3 existing floorboards and 1/3 chipboard (in new extension). Unfortunately the new floor will be laid the same direction as the existing floorboards. I realise I will need to lay some ply on top of this and to keep the levels the same I will need to continue the ply into the extension. My question is: What is the minimum thickness of ply I can get away with? Should ply just be screwed down or glued and screwed? Is it better to use portanailer throughout both floor types? Should I also lay 2mm underlay to dampen noise? All advice will be most welcome. Thank you, Mark
Hi Mark , I would cover both old and new floors, with plywood, then it doesn't matter what way, you run your oak , just screw down ply , no need to glue . Hope that helps
Thanks Gatt. I have come up with a new plan; I just wondered what your thoughts are on the following? The old part of the house is floorboards which are in good condition and are flat. I have just finished screwing every board at every joist to reinforce and reduce any creaks. The new half of the house is new 18mm t&g chipboard. I now plan to lay the oak diagonally throughout the house (I appreciate the additional work and waste). I plan to lay a 2mm foam underlay to further reduce any potential creaking. I plan to secure the full floor with tongue tite screws as this is more convenient for me. I would need to hire a nailer over a few weekends where this way I can spend every evening installing screws which is less noisy and less expensive (I have done the sums). I also believe the screws will be better in the chipboard than portanails. I guess my question is... Does this sound a good plan? Is there anything else I should consider? Is there any harm in either using underlay or full install of tongue tite screws? Thanks again, Mark
Hi Mark , u can put the 2mm foam under , just watch it doesn't foul between boards . I would just go with porta-nailer , nails are designed to hold tight, safe yourself a lot of time, good luck.
